Communicating with Fluke 9100S Temperature Calibrator via RS-232
Still pretty new to LabVIEW, so I hope to get some insight and suggestion to the problem.
Objective - To establish basic communication with the 9100S Temperature Calibrator via RS-232 (Read temperature values and input setpoint temperature values)
Problem - The device has Interface commands that can be used to read and input setpoints into the device. I am seeing that the devices is communicating with LabVIEW VI, but i am not able to input setpoint and the data read is some kind of                        machine code. All i need to perform is to read the temperature value and input setpoint into the device.
I am attaching the VI that I created, and other supporting files and screenshots to illustrate the problem. The images attached are the runtime results of the VI's and the interface commands for the device. I have the serial drivers and supporting software's installed. Please help me solve this problem. Would like to get suggestions and insight on this matter.
themadgreek
(1,496 Views)
You failed to attach your VI.  The only real gotcha I am seeing from the data sheet is that the termination is a Carriage Return, so you need to make sure your termination character is set to 0x13.
GCentral
(1,485 Views)
I have edited the original message with the VI's
thanks
themadgreek
(1,476 Views)
I'll continue this on your other thread.  There's no need to fork the discussion.
GCentral
(1,422 Views)
Hi @Crossrulz,
I wasn't meaning to fork the discussion. It seemed like i didnt give a good explanation of what i was trying to implement, and i could not edit the original message a second time, so i thought of cretaing a new discussion with a bit more explanation.
themadgreek
(1,404 Views)
