Has anybody programmed Chroma Load 63302 model using LabVIEW before?
I dont have much difficulty in getting started with the instrument & communicating with it using RS232.
But today I encountered a small problem. It has in total 4 channels. When I tried to load it using the Chroma Load 63302.vi, Channels 1 & 4 got loaded fine in the first run itself for CC mode. But Channels 2 & 3 got loaded in the first run only sometimes; sometimes they required a second run of the VI (which took quite a long time before it stopped) to make them load in the CC mode.
Also, there is a switch L/R (Left/Right) for appropriate channel selection to load on the Chroma panel. But I didnt find any driver VI to control this option. Does anybody have idea how to do this? I dont have the hardware command manual to look for the proper command. As far as I looked into the driver VIs, the commands seem to be simple for almost all the functions. If somebody can guide me with a proper command for this option, that will be fine too.
Appreciate your help in advance...
- Partha ( CLD until Oct 2024 🙂 )
