Character loss during write operation using VISA
Hello, I’m trying to develop a serial communication program in LabVIEW to communicate with a device and send commands, but I’m experiencing issues with data writing. It seems that the data is being transmitted; however, characters 14 and 15 of the string are missing.
If you send a character string shorter than 14 characters, the command is accepted. When using PuTTY, the full command is transmitted and executed successfully.
(364 Views)
Accepted by topic author Robinet1
What device are you trying to communicate with?
My initial guess here is that the device has a really small UART buffer and you are actually sending the device too much for it to handle all at once. A Putty terminal sends as fast as you type, which is horribly slow in comparison to dumping a full string into the VISA Write. If this is the case, try breaking up your serial write into 10 byte transmissions with a small delay (10ms as an initial guess) in between.
(361 Views)
I followed your advice and now I can send commands via VISA.
Regards
(340 Views)
