03-07-2021 03:29 AM
Jpeg File transfer from Instrumental to PC.
Hello, Please give your help regarding captured Jpeg file transferring from instrumental to PC via NI-VISA on VB.NET with followings.
DMM.WriteString("MMEMory:DATA? 'AAA.jpg'")
out_Msg = DMM.ReadString
returned message includes <header> and <Bindata>.
<headder> includes Len of Bindata(num of byte).
So I removed <headder> part and converted it to byte style by following.
Dim bs As Byte() = System.Text.Encoding.GetEncoding("shift_jis").GetBytes(remain_msg)
And wrote it as binary.
fs.Write(bs, 0, bs.Length)
After that, File was saved as Jpeg but can't open as pitcure.
I compared with original Jpeg got from instrumental.and I made via above. Actual File size is little bit different from original jpeg.
Also character corruption are seen.
Does someone has idea to fix it ? or any good sample program ?
03-12-2021 06:46 AM
I could transfer jpeg File from instrumental with following method.
1)Request instrumental to start data transfer.
2)Read message by "ReadIEEEBlock".
out_Msg = DMM.ReadIEEEBlock(IEEEBinaryType.BinaryType_UI1)
out_Msg should be defined as byte.
3)save as binary file
Dim fs As New System.IO.FileStream("C:\AAA.jpg", System.IO.FileMode.Create, System.IO.FileAccess.Write)
fs.Write(out_Msg, 0, out_Msg.Length)
fs.close
