04-26-2010 01:11 PM
Thanks KC,
I will investigate the resistance when I get some time, for now I'm using a work around so I can get the code up and running.
I have tried the connection both with and without a ground and neither worked.
05-11-2010 02:16 PM
I did get this to finally work today! I ended up changing the PXI card to a free slot. I left the default settings and set the 2 wire auto mode using a property node in the program and it works. I still have to go back and determine if it's the slot or the settings that were causing the issue.
Thanks to everyone for the help
05-12-2010 01:57 AM
Hi John,
Nice to see things are working ok.
Strange, I use a PXI-8431/2 (and PCI-8431/2) and set the mode in MAX to 2 wire auto. I did not use a property node to set the mode and it works just fine.
07-07-2010 10:06 PM
07-08-2010 09:08 AM
04-19-2022 09:22 AM
resolved
