Cannot configure GPIB in Windows Server 2008
I have installed the version 2.8 IEEE488 driver on a Windows Server 2008 machine.  I successfully added a GPIB-ENET interface under Measurmeent and Automation Explorer; however, it will not allow me to make configuration changes to the interface.  I have the "GPIB Interface properties can only be changed by an Administrator" message in the status bar.  I am in the Administrator group for this machine.  Does anyone have any suggestions?  Is there a different user group I need to be in?  File permissions need to be set?  Is there another configuration setting I need to make?
(3,079 Views)
Accepted by topic author mcnecaise
I solved the problem.  Run as Administrator.  Not enough coffee this morning.
(3,078 Views)
