01-12-2022 08:30 AM
Hi Community,
I have in my Lab a old Agilent Networtkanalyzer E8358A with Labview 2021 running via NI USB-GPIB adapter without issues with NI.-Max and Labview 2021.
In a Windows 11, DOS Shell I can ping it with the TCP/IP (192.168.178.10) also without issues and can transfer data from the Agilent file system to the Windows 10 PC also with no problems.
But to improve the Data transfer speed I want use the Ethernet Interface in Labview or NI-Max programms but without success, under NI-Max it is not detected properly and I don't know why.
Also a right click in NI max on the newwork divice will not open the VISA test panel.
Maybe can someone give me a hint where I must enable or do something else to commuicate via TCP/IP with Labview.
Best regards
antenna guy
01-12-2022 07:35 PM
You can try to see if you can PING it in the shell.Which version of VISA do you have.
01-12-2022 07:36 PM
Sorry, you can ping it. I missed it
01-12-2022 11:46 PM
Probably the reason why communication is not possible is that the LAN device name is blank.
The standard LAN device name for communicating with VXI-11 is inst0 for most measuring instruments.
NI-MAX : Devive and Interface -> Network Device -> Right Click -> Create New VISA TCP/IP Resource -> Manual Entry of LAN Instrument -> Next -> IP address : 192.168.178.10 LAN device name : inst0 -> next -> finish
01-13-2022 03:48 AM
also with Lan device Name inst0 is not working or detecting in NI-Max.
See attached picture, of NI Max screenshot it works with GPIB Adress 16 without issues via NI-USB-GPIB Adapter.
Also in the Windows shell I can ping via Ethernet to 192.168.178.10 without issues (see picture)
The NI Max has Version 21.0.0f0
More hints what I can try ?
thx
antenna guy
01-13-2022 04:51 AM
When I searched for and read the manual on the Web, it seems that the E835xA does not have the VXI-11 function, and only Socket communication can be used on the LAN.
Change the newly created network resource to Raw Socket and try again.
(The port number is 5025.)
01-13-2022 09:10 AM
thank you for you help it works a little bit with the Port if I installed from scratch (delete the old one in NI Max).
See attached first picture, after that prodedure I saw the whole stuff in NI-Max working.
If I reboot the Windows 10 PC again and restart NI-Max again than it didn't work see picture 2.
Do you have additional tip that it work permanently also after reboot the Windows PC ?
Thank you
antenna_guy
