From 01:00 AM CDT Saturday, June 10 - 04:00 AM CDT Saturday, June 10, ni.com will undergo system upgrades that may result in temporary service interruption.
Can Keithley 590 CV analyser be used as LCR meter?
Can someone tell me if the Keithley 590 CV analyser be used as a LCR meter in the sense that a frequency scan can be done?
I need to do a frequency scan using the 590 CV analyser but only two static frequencies are available on the meter, which are 100 kHz and 1 MHz.
Thank you.
(2,080 Views)
The 590 is an ancient and simple CV meter, and its not capable of doing frequency scans but only reading CV at two distinct frequencies; 100kHz and 1MHz.
You should consult the manual here for full details - https://www.tek.com/manual/model-590-cv-analyzer-instruction-manual-rev-d-197mb
Keithley doesn't seem to make modern stand-alone LCR meters, but Keysight does - https://www.keysight.com/en/pc-1000000391%3Aepsg%3Apgr/lcr-meters-impedance-measurement-products?cc=...
Craig
(2,068 Views)
Hello Craig,
Thank you for your reply.
Yes, I did look into the manual and I didn't find anywhere if it can do frequency scan.
I am actually trying to measure interstrip capacitance of silicon sensors and I can't seem to figure out how to do the frequency scans.
I'll have a look at the LCR meter you recommended, thanks
(2,062 Views)
