Can I use a sub cam on CRio 9049?
hi all,
I'd like to get continuous image from USB cam(intel REALSENSE) that is connected to the USB port on CRio 9049.
But I don't know where I can get image (I/O node, or something).
I've seen previous forum(https://forums.ni.com/t5/Machine-Vision/USB-webcam-on-a-cRIO/td-p/3327542), but I cannot find webcamera support of crio 9049.
I'm new to FPGA, so if you need more information, please tell me.
Thank you for your attention.
(144 Views)
Accepted by topic author cleska
I suppose you'll be able to get image on RT target not on FPGA target. Please check it. I don't think there is I/O node for camera on cRIO FPGA target.
(93 Views)
Hi, vardanium.
Thank you for your reply.
I understood where I should grab the image.
Now, I can use the usb port on cRio, and run host program on cRio.
Again, thank you for your kindness!
Best regard,
CleSka.
(88 Views)
