Can I use USB hardware interface as GPIB interface?
I want to connect GPIB interface over USB connection. I have choosed GPIB interface on the oscilloscope but I see only USB connection on the NI Max program. Can I use USB hardware interface as GPIB interface?
If this is possible what should I do?
All information in the below.
SETUP
- Keysight InfiniiVision DSOX3024T oscilloscope
- Keysight DSOXGPIB GPIB Module
- USB cable
- NI MAX (NI VISA + NI-488.2 driver)
- I have chosed GPIB interface on the oscilloscope.
(1,268 Views)
Accepted by yesilyurt
You'll need a USB-GPIB adapter for that such as: https://www.ni.com/nl-nl/shop/model/gpib-usb-hs-.html
Rolf Kalbermatter  My Blog
(1,247 Views)
Either an NI variety USB to GPIB as rolfk mentioned or a lower cost option like the Prologix GPIB-USB Controller and use the notes here that I have provided.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(1,235 Views)
