09-14-2017 03:57 AM
I'm trying to connect my digital multimeter with labview 2016, i downloaded the driver for the UART bridge in silicon labs website and all is working OK, in the MAX, VISA test panel > Input/Output i send the IDN command and its working its sends the model and version of the multimeter.
So, i need to connect the multimeter with labview, for collect data and start working on my experiment. What i need to do for start capting data from multimeter? I need to do instrument driver? or i need to do a program in labview to read serial port??
The multimeter es Chinese and in labview i cant find the driver of my multimeter.
The multimeter is a TH1942 USB with cp210x USB UART bridge for pc connection.
Thank you for help!!!
09-14-2017 04:32 AM
If there are no driver library, then pull out the manual and figure out which commands you need. It will show up as a serial port, so you can just use VISA to write to and read from the DMM.
09-14-2017 07:10 AM
Thank you for your answer, but how i can read the data with VISA Test Panel???
Only i can write commands (TH1941 manual) to change between ohms and volts and this kind of commands.
But how can i receive the data from the multimeter?
In the manual, they purpose a comunication program example in C language, but i need to use it in labview, how i can do it?
09-14-2017 07:30 AM
Have you looked in the palettes at all? There is a whole palette just for VISA communications (Instrument I/O->VISA).
09-22-2017 07:27 AM
Hi crossruiz,
I done the comunication and write data in txt file, adding some subVis. But I think the read or the write is too slow. Now is capting 5-6 values in one second. But my multimeter transfers at 25Hz, 25 values in one second, how i can sinchronize it for get a real reading?
Thanks for helping!!
