05-27-2015 08:56 AM
Has anyone already controlled a CAMTEC power supply with an USB2.0 UI.Drive-Interface by LabVIEW ?
Many thanks in advance for any advice.
05-27-2015 09:29 AM
Looks like you'll need to call a .NET DLL unless they wrote some wrapper LabVIEW VIs .
06-23-2015 03:46 AM
You can use the "CAMTEC Netzteilansteuerung USB2.0 UI.Drive-Interface" which provides a .NET library for LabVIEW. It can be downloaded here.
I have rewritten it because it doesn't satisfy good programming style.
