Bug Report: Tek DPO 4000 oscilloscope driver (won't Recall Setup)
There's an error in this instrument driver: tkdpo4k\tkdpo4k.llb\tkdpo4k Save-Recall Setup.vi
Save Setup works but Recall Setup doesn't.  On the block diagram, Recall case, the 'Initial String" input constant to "Format Into String" vi is "*RCL"  It's missing a trailing space as in the Save case "*SAV ".
(3,491 Views)
Me again...same Vi.
While we're at it, the addressing of the location to save and recall setup is off by one. The old 0 vs. 1 index for the first value of an array.  The setup storage locations for this scope are 1 through 10.  This 'tested' instrument driver tries to address them as 0 through 9.
(3,490 Views)
Hi chris8332,
Thank you for the feedback. We will try to reproduce this issue on this side and check it out.
Thank you!
Chris T.
(3,455 Views)
Hi chris8332,
This was reported to R&D (# 285920) for further investigation. Thank you for the feedback!
Chris T.
(3,427 Views)
