Best power supply for 6218
I'm a simple biologist looking to get an electronic power supply with two or more channels that can be easily controlled by a USB 6218.  Ideally the power supply should be able to be adjusted at 0.01 volts between 0 and +/- 24 volts but +/- 12 volts would also be acceptable. My budget is around $1000 US.
Cheers
Josh
(3,026 Views)
Why do you want to use a 6218? You can find serial, USB, Ethernet controlled power supplies that would not require one. Check Agilent, Keithley, Lambda, Sorensen, Kepco, etc. A google search will turn up many more. And, if you are using LabVIEW, find one that already has an instrument driver and simplify your life even more.
(3,018 Views)
