08-08-2019 12:47 AM
Hi all,
Updated to Visa 19.0 and NI-MAX visa option doesn't have option to activate Tulip.
Found the link below and tried but it didn't work.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000015CnsSAE&l=en-AU
The error message is shown below.
Can anybody help me with this?
Thanks.
08-14-2019 04:25 PM
What version windows do you have and do you have admin rights on that particular computer?
08-14-2019 06:27 PM
It is Windows 10 version 1803.
Yes, I have admin rights. Thanks.
08-14-2019 07:38 PM
Also copying error message in command window hoping it can be a help.
08-15-2019 03:02 PM - edited 08-15-2019 03:04 PM
Ok, this might just be me being dumb because it's been quite a while since I've done command line stuff but the file I ran was a .bat . It also worked perfectly. The first error you posted was stating that the installation file could not be opened, leading me to believe that the extension was wrong.
Additionally, no where in the second image do I see "RestoreTulipPassport.bat "
Am I missing something?
08-15-2019 08:57 PM
Yes, I also ran bat file 'RestoreTulipPassport.bat' which pops up this cmd screen with error message.
08-15-2019 09:01 PM
So basically when I run bat file, it pops up two windows. One is the cmd window and the other is the Windows pop-up dialog with error message.
08-16-2019 01:16 AM
Perhaps give up on the batch file and try installing NI-VISA again with the offline installer that you can get on NI website?
08-16-2019 01:25 PM
I was able to duplicate your error midam7 ! Granted... on a Windows 7 Machine, but still. I duplicated both your cmd window and the Windows pop-up dialog.
When you go into NI Max -> Tools -> NI-Visa -> Visa Options, is the Tulip passport still missing or is it visible?
08-18-2019 11:33 PM
Tulip passport is missing - see screen shot below.
