Assistant I/O is not working with new version, not normal failure, please read.
Im trying many days to find a solution for this problem. I made a programm for steering a steppmotor. Everything works great. I made the software with Labview 8.5 and Visa 4.2.
Now I installed labview 2009 and the newest Visa version, I removed the old one first. I tried the software and it works normal. But If I open the visa assistant I/O user interface to change some properties, than it will not work after safing. Even if I open the assistant I/O userface and safe it without changing, it will still not work .
I removed all the assistant I/O and made it new but it does not work. Any ideas ??
Thank you !!
(3,853 Views)
I would have to know which exact device you use.
Smiley Very Happy
Marko
(3,838 Views)
Im using a microcontroller from Nanotec (smci12) and its communication cable rs485 to USB adapter. I installed Visa Version 4.60 and it works. But it seems that there are still some errors, sometimes it sends no commands or just slowely...
(3,833 Views)
Hi Dimasq,
I need a example VI or the Project.
Witch errors occurred, please describe or post a screenshot.
Are you using an application? If so, please pay attention to set the checkbox in your application builder---> Advanced--- Use Labview8.x file layout.
I need more information about the vi and the environment.
Best regards
Christian
(3,814 Views)
Hi , sorry for the delay. Ok I can show you the VI .
Labview Version: 2009
No error occurs, it is just not working with the newest version. Now Im using 4.60.
Best regards !
(3,797 Views)
Hi Dimasq,
Thanks for your VI, are you sure that the VISA and NI-488.02 driver are correctly installed?
Please look at thease links and if it not works try to install all NI-Device Drivers.
How Can I Fix an "Instrument I/O Assistant Not Installed Properly" Error?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019L3NSAU&l=en-US
NI Device Drivers 2011.02 - Windows
https://www.ni.com/en/support/downloads/drivers/download.ni-device-drivers.html#327626
Hope it helps,
Christian
(3,789 Views)
