Downloaded the Ametek/Sorenesen power supply IVI and labview drivers from 3rd party website. Ran import wizard and have AmetekXG pallete. Almost all VI's fail with "Unknown physical repeated capability selector errors". However, NI-MAX does not display the IVI driver so o that you can assign a channel number/name to eliminate this error. What is the proper configuration in order for this process to work properly?
Hi, for similar cases, this error has been fixed by going into the driver session in MAX, click on the Virtual Names tab and add the channel name there. However will need to find the IVI driver in NI MAX. Have you tried re-installing the drivers?
