‎06-06-2007 11:01 PM - edited ‎06-06-2007 11:01 PM
Message Edited by anthropoid on 06-07-2007 12:06 PM
‎06-07-2007
08:57 AM
- last edited on
‎03-11-2024
09:19 AM
by
Content Cleaner
I'm not sure why the rep suggested that card to replace the PCMCIA version. Perhaps he didn't completely understand the requirements. If you head over to NI's Products section you will find options. For instance, they have a USB-GPIB device. There are also ethernet-based ones. The list is here.
CORRECTION: It doesn't look like those devices support the analyzer part of it. How critical is this?
Message Edited by smercurio_fc on 06-07-2007 08:59 AM
‎06-12-2007 04:04 AM
Unfortunately, it's a deal-breaker. The use case is field diagnostics for semicon test equipment, in which a field engineer alternately snoops on the GPIB bus between tester and handler (to capture full interactions rather than just data traffic) and sends data out to emulate tester or handler.
‎06-12-2007 09:06 AM
