05-31-2023 10:52 AM
I am remotely controlling an E4448A PSA Series Spectrum Analyzer. When asked SYS:VERS? it responds with 1997.
I have successfully remotely controlled the Phase Noise measurement data collection but I need to be able to also take a screenshot.
I have had the screenshot functionality working for a while.
The problem is that I cannot get the reference level to change to bring the signal into view for the screenshot.
I have tried many variations of commands found in different documents but none do the trick.
For example, I can query DISP:MON:WIND:TRAC:Y:SCAL:RLEV? which returns 0, then set it DISP:MON:WIND:TRAC:Y:SCAL:RLEV -40 and query again and get -40.
So it's changing something but nothing happens on the screen. The reference level for the log plot remains at the default -70.
It appears to be changing something outside of the Phase Noise personality.
Any changes to the command to include LPL result in an undefined header error.
I have scoured the PSA Series Spectrum Analyzers Option 226 Phase Noise Guide, the User's and Programmer's Reference, Volume 2 One-Button Power Measurements as well as N9068A & W9068A Phase Noise Measurement Application User's & Programmer's Reference to no avail.
Any suggestions appreciated.
Solved! Go to Solution.
05-31-2023 11:10 AM
Any success reaching out to Agilent technical support to see if it is actually feasible over remote control? maybe that specific firmware doesn't support?
06-07-2023 06:18 PM
No luck with Agilent. They sent me to Keysight who no longer supports the model E4448.
I ended up just saving a state with the reference level where it needs to be and remotely recalling the state, which is not ideal but will suffice.
Thanks!
