Agilent 82357A USB to GPIB (non visible by VISA)
I am currently runing kubuntu, linux version 3.19.0-30-generic. KDE plasma version 5.2.2. And i am tryin to use Python to communicate with a  'Maturo Control Unit' (or MCU version 1.30). In orde to do so i am using Pyvisa (version 1.5) and a Agilent 82357A USB to GPIB. When i am using the terminal i can send and reseive commands from the MCU. But when i use Pyvisa's resource maneger the Agilent 82357A USB to GPIB with the MCU connected does not appear. Pyvisa does work. Because ive used it in the past to connect with a spectrum analyzer using TCP:IP.
How can i make Pyvisa show the Agilent 82357A USB to GPIB connected to the MCU?
python 3.4.3:
>>> import visa
>>> rm = visa.ResourceManager()
>>> rm.list_resources()
(6,754 Views)
I'm unsure of why you are posting here. You aren't using any NI hardware or software. Check with Keysight about their GPIB driver and your version of Linux.
(6,738 Views)
SOVED
(6,653 Views)
Hi
I have same problem. Could you share it with me?
(4,115 Views)
You'll need to talk to Keysight (formerly Agilent) to see if they have linux drivers for the USB-GPIB adaptor.
(4,101 Views)
Sorry it has been a long time since i worked on that internship. I believe use import GPIB in order to get it working. I hope this helps.
import gpib
class GPIB(object😞
    def read(instrument):
        device = gpib.dev(0,instrument)                                     #Maakt verbinding met de maturo control unit ()
        responce = gpib.read(device,8)
        #print(responce)
        return responce
    def write(data,instrument):
        device = gpib.dev(0,instrument)                                     #Maakt verbinding met de maturo print(device)
        command = data
        gpib.write(device,command)
    def GPIB():
        pass
(4,085 Views)
