11-02-2018 11:24 AM - edited 11-02-2018 11:25 AM
The instrument driver listing at http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=0470714759413BCCE0440003BA7CCD... skips from LV 8 to LV2015. Is there an NI support link where I could ask if any of these drivers are compatible with LV 2013 ?
Jeff
Solved! Go to Solution.
11-02-2018 02:24 PM
The LabVIEW 8 version can probably be used with LabVIEW 2013 without any issues. The newer version aren't backwards compatible but the older version will be "upgraded" when opened in a newer LabVIEW version. You'll be asked to resave it for 2014, which is usually fine.
Craig
11-05-2018 10:04 AM - last edited on 01-08-2024 03:10 PM by migration-bot
Craig is correct - you should be okay with the LabVIEW 8 driver. As detailed here, the VIs in the driver should open fine in LabVIEW 2013.
