03-28-2008 01:11 AM
03-28-2008 08:38 AM
You might want to first try the driver here. Use the import CVI driver tool (Tools>Instrumentation).
LabVIEW 8.x has the Create Instrument Driver Poject wizard and this creates an instrument project based on a tmeplate or an existing driver. The VIs it creates are typical of what you might need (i.e. Configure Trace, Configure Marker, Read Trace, etc), and if you've nver created a driver before, will save you a bit of time. The VIs do have some SCPI functions but you will still have to do quite a bit of writing code in order to implement the commands that your instrument actually uses.
Other than that, there is no difference between the VISA functions in 7.1 and 8.5. I do think the upgrade to 8.5 is worth it for a lot of other reasons.
03-28-2008 03:19 PM
