11-19-2013 11:45 AM
Hi Erik,
Could you share how you control iHR320 spectrometeter?
Petro
11-19-2013 01:40 PM
Here are the VI's from Horiba's website (2009 version) for USB controlled monochromators (iHR320, iHR550 & more). Note that these require first installing either SynerJY or the "USB Spectrometer Utilities". Either of these install the DLLs that are utilized in the LabVIEW vis. Also of note is that these were designed for windows 2000,XP. If you are running a 64-bit operating system you may encounter problems detecting the monochromator due to a different registry path.
I've noticed that the initialization vi, as written, sometimes fails to utilize the correct device name on my computer (Mono1 for my system) so I ended up making it a constant for my system (something to consider).
11-19-2013 02:06 PM
Thanks a lot,
I have USB spectrometer utilites on CD, and it is installed. But I cannot see JY .. library listed in OLE explorer. I will give it better look tomorrow. I also hope it will work with labview 2012.
03-17-2016 08:16 AM
This is a very old thread, but since I am trying to use exactly this spectrometer with LabVIEW I would like to ask why I don't see the VISA (or whatever) calls in the VI hierarchy view of this package. I would like to determine exactly which calls are made to the Horiba driver.
Thanks in advance,
Luis
03-17-2016 08:39 AM
Hi Luis,
It's indeed a while ago.
We never use the setup so it's all a bit rusty.
There is no standard visa driver. You need the standard software to control the spectrometer.
With ActiveX you will be able to do the programming. (There are some demo files)
We use the labspec software which came with the setup.
So first step.
Is you device running with the supplied software and which software do you use?
03-17-2016 09:02 AM
Hi, thanks for the quick answer!
We have been using the standard Horiba SW, JYUSBMonoConfig. We have also downloaded the Horiba VIs:
USBMonosNew With ShutterVIs LV2009 SP1_WinXP
, albeit in a different computer as we don't want to disrupt the production environment. I was in the process of analyzing those VIs.
03-18-2016 08:16 AM
OK, now I see the DLL calls. Since they are not installed in the development environment, I get an "Invalid method for this class". I guess that's the reason. However, I am seeing the classes in the DLLs (things like IJYMonoReqd) which is what I wanted.
Thanks a lot!
10-29-2018 08:23 AM
This is krishna, I'm using a iHR320 spectrometer with synapse CCD. from labview drivers I'm using a read detect uniq_id.vi its not detecting any device. Also using synerJY software to controll the CCD+spectrometer its also not communicating I have noticed this issue recently with SynerJY software previously it was working but suddenly its not working now.
I have tried with other VIs also from global and user_lib provided by HORIBA. No VI is detecting my devices (connected through USB). I'm Using win7 64bit OS.
Can anyone help me in this. it would be a great help.
Thank you.
11-01-2018 05:15 AM
Hi Krishna,
The National Instruments Customer Care Team has received your inquiry. I would like to forward it to our Application Engineer Team. Would you be so kind and resubmit your request and send it to the info.belgium@ni.com email address please so we can raise a service request for you? Would you include your contact information as well please? Thank you in advance!
Kind regards,
Monika
M. Monika Feher
NIE Customer Care CSR
02-17-2019 10:02 PM
I have connected CCD (synapse) and Spectrometer (IHR320) to Labview. Now the drivers from Horiba (User.Lib) like spectral mode CCD VI is working. we could see the Noise spectrum.
But,
We are unable to get the required wavelength from CCD. we have tried with 600 nm source light and with white light. But still CCD showing noise in spectralmode.vi programme.
Can anyone know how to resolve this issue?
