07-20-2010 11:05 AM
The 64-bit beta installation from http://joule.ni.com/nidu/cds/view/p/id/1000/lang/en went flawlessly.
According to /usr/local/natinst/ni4882/gpibexplorer the device GPIB0 exists and is working, but it doesn't seem to show up in /dev/ in format that iccap is looking for.
iccap is looking for /dev/gpib0 and the closest looking device is /dev/nipalk. What am I doing wrong?
This sounds like a there is a simple solution such as a symbolic link or something.
07-21-2010 05:30 PM
Hi Toulon,
Can you successfully run example programs with this card or communicate with your instrument via ibic?
07-22-2010 05:24 PM
Hi Toulon,
I also wanted to check to see if the iccap software that you are running is 32-bit or a 64-bit application? The 488.2 driver has no 64-bit language interface, and thus is has kernel mode support only.
