02-11-2008 06:01 AM
02-11-2008 08:41 AM
02-08-2009 01:53 AM
I have the same problem , comunication with Easy control relay 800 series, I have bought an Easy 2004 DP and the documentation from Moeller but I had yet found any solution .
If you want I can sent you the manual to look on it , if you want.
Another way to comunicate is by direct programing in Easy soft a serial protocol , in this way you can comunicate with the serial port available on the front of the device.
Gabi
