02-01-2013 04:05 AM
Hi there,
i have the task to implement a communication between multiple cRIO's and the NI-OPC-Server. The NI-OPC-Server has to act as data handler for a complex frontend.
I tried out the NI-OPC-Server and i was successful in communicating with the NI-OPC-Server as OPC-Client in Windows using an IO-Server and Shared Variables. But the task is to do this on a cRIO. I tried to open a data socket connection from a cRIO to the NI-OPC-Server using a specific URL using "DataSocket Select URL.vi". But as long i do not activate simulation in the NI-OPC-Server i get errors on opening the data socket connection. If i do activate the simulation, which is not the solution, i can write some data without error but the Quick Client of the NI-OPC-Server sees no changes for that data tag.
I have the feeling i am not at a good way to get this working. Is there anybody having experiences with this? Is data socket a possible way at all? Is it possible at all? Do i need to implement a cRIO-OPC-driver?
Thank you.
Solved! Go to Solution.
02-07-2013 10:52 AM
There's one pretty good tutorials and one webcast. Have you already study them?
http://www.ni.com/white-paper/7450/en
http://zone.ni.com/wv/app/doc/p/id/wv-263
Chers,
Philip
02-08-2013 03:38 AM
Hi there,
i found the solution in this article:
http://www.ni.com/white-paper/7451/de#h36
Thx for your help.
03-29-2018 11:44 PM
hi
so what is the solution?
instead of pointing some URL it would be better if solution is specified point wise.
12-15-2020 05:25 AM
