06-20-2018 09:39 AM
I am using REM-11120 on etherCAT for temperature measurements. Following the user guide when I connect a thermocouple and write a sample VI, it shows a constant value (-32764), which never changes.
I followed a below instructions to write a VI for REM-11120
http://zone.ni.com/reference/en-XX/help/372626P-01/indcomecat/scale/#instance3
Please guide me in this regard.
Thanks in advance!
06-21-2018 12:33 AM
Did you deploy the EtherCAT master and change the Scan Engine's mode to Active?
Did you try to change the temperature and check if the value showed (-32764) changes?
Can you provide your LabVIEW project here?
06-25-2018 03:32 AM
Thanks for your reply!
I followed the given example for REM-11120, and it started working!
Cheers!
