02-22-2013 03:20 PM
After cRIO Profibus Module is set to communicate with MVI56 PDPMV1, how is the control tags of 1756 -L73 mapping into addresss of cRIO Profibus Module ?
02-22-2013 04:42 PM
Hi Rig,
It sounds like you already used the Configurator to get the MVI56 PDPMV1 configured, correct?
If so I think your best bet is looking at the examples located at: C:\Program Files (x86)\National Instruments\LabVIEW 2012\vi.lib\addons\Comsoft.lib\Profibus VISA Driver. Save the Master example to a different name and use it as a starting point.
Do you have the manual for the MVI56 PDPMV1? The input bytes from the master should be pretty standard in profibus. Any differences will be explained in the manual.
02-22-2013 05:48 PM
If I have cRIO-9014 controller ,cRIO PB , cRIO 4215 , How the cRIO-9014 controller can communicate with MVI56 PDPMV1 through controller tags of 1756-L73 ? Could you give me a simple example ?
02-22-2013 06:12 PM
Hi Rig,
I don't have an example program specifically for that controller. I can help you figure it out- I need more information from you though. Can you clarify these points
1) Were you able to configure the profibus network with the configurator?
2) Do you have the user manuals for the 1756-L73 and MVI56 PDPMV1? Can you post them here?
3) Did you find the examples I posted above and look at them?
It looks like you will have to setup the cRIO as a profibus slave for the MVI56 PDPMV1
02-22-2013 10:31 PM
Hi Jesse,
1) I did not configure the profibus network with configurator .I only suppose to be able to configure it .
2) I have manual of 1756-L73 and MVI56 PDPMV1. you see it in attachment that will be attached .
3) I didnot find the examples about them .
Yes, I had to configure cRIO as a profibus slave for the MVI56 PDPMV1 and MVI56 PDPMV1 is a profibus master.
Could you directly answer My below questions as you can ?
1. If I have cRIO-9014 controller with cRIO PB , cRIO 4215 , what are operation system softwares in cRIO-9014
Control ?
2. How does I configure cRIO-9014 controller in operation system softwares to control I/O cRIO 4215 and set up a communication of cRIO -9014 with PLC .
3.or how does cRIO-9014 controller vist the tags of PLC .
3.If cRIO-9014 controller with cRIO PB , cRIO 4215 are successfuly communicated with MVI56 PDPMV1
How does cRIO-9014 controller know the tags of PLC through profibus of MVI56 PDPMV1 ?
02-22-2013 10:40 PM
please see mvi56 pdpmv1 manual .
02-25-2013 09:18 AM
Hi Rig,
-If you can't find the examples I mentioned the PB driver may not have installed correctly and you may need to re-install. I highly recommend you focus on tracking down those examples. Additionally, there is a getting started guide in the Comsoft installation directory (C:\Program Files (x86)\Comsoft GmbH\cRIO PB\Help). It will walk you through installing software on a cRIO.
1) You will need to install Real Time and Profibus. This is explained in the getting started guide referenced above
2) This is a basic programing task for the cRIO. The examples I referenced show how to use the Profibus API in labview. If you haven't use a cRIO before there is more basic information at ni.com/gettingstarted
3) See the examples I referenced. Tags are referenced through the LabVIEW Profibus API.
4) The 9014 is a slave on the Profibus network. It only responds to messages from the master. While there are otherways to read tags from the controller with a 9014, I don't think you will be able to with Profibus. This is a limitation on the profibus specification. You can, however, write output data to the 9014.
You keep referencing a cRIO 4215 but I don't know what module that is. Can you link a product page?
02-25-2013 09:58 AM
02-25-2013 07:04 PM
Hi Rig,
The 9215 programming issue is completely separate from the Profibus module question. I suggest that we focus on the profibus issue at the moment. Programming the 9215 will not be difficult and you can find prebuilt examples at ni.com/getting started or in the LabVIEW example finder.
Thanks for getting the user manual. There is a getting started guide at C:\Program Files (x86)\Comsoft GmbH\cRIO PB\Help that explains how to copy the COMS0B57.GSD file so that you can configure the profibus master. Can you follow this guide and let me know when you hit hang points?
02-26-2013 12:41 PM
Hi Jesse,
In cRIO PB DP -getting started Slave manual in page 15 /23 , who decide the index of header strurcture ?
