11-28-2018 09:59 AM
I have several different Kunbus configurations saved for my Profibus networks. Currently the only way I can download a configuration to the cRIO is through the Kunbus Configurator III tool. Is there a way I can programmatically download a configuration using LabVIEW?
Thank you.
12-26-2018 10:30 AM
Hi AJLNVA,
There isn't a way to do this with the cRIO PB driver distribution. The method for downloading the configuration to the module is as you described through Configurator.
How big of an impact is this to your project?
Some programmatic changes are possible with the PCI / PXI DF PROFI II - related thread.
-Andrew
01-02-2019 12:49 PM
Thank you for the reply Andrew. Unfortunately, not being able to programmatically push new configurations down to the cRIO PB module will be a big impact to my customer. In the system that I am replacing the end user can select from a menu of hardware configurations to match how the actual hardware is installed and the software calls up the correct configuration file (.2bf currently). I was hoping I could get that same functionality with the cRIO PB module. If some programmatic changes are possible with the PCI/PXI DF PROFI II do you think its possible to expand this to the cRIO PB?
R/
AJLNVA
01-03-2019 07:58 AM
There might be a way to programmatically download the CFG file to your module using a modified configurator DLL and an example.Please contact me directly under dirk.wieprecht@ni.com.
-DirkW-
01-11-2019 02:31 PM
Here is the download tool for LabVIEW 2014 or later.
-DirkW-
02-24-2021 01:02 PM
Does anyone have a POC at NI for Profibus? I tried to email Dirk and the email was kicked back. It appears Dirk may no longer be at NI. I am looking for a refresh of the tool he provided via this thread before. I now have a cRIO-9055 and LabVIEW 2020 and the tool he provided before does not support the 9055.
Andrew
