02-02-2010 04:19 AM
Does anyone have experience in using Profinet from LabVIEW?
I would like to connect some LV applications to a siemens PLC using profinet.
Is there special HW required?
Thanks!
02-02-2010 06:45 AM
Hello Ben,
Profinet requires deterministic timing and onboard CPU power to run the protocol. Thus you need a Profinet interface board. In the area of Profibus/Profinet National Instruments cooperates with Comsoft and they should have a Profinet board with good LabVIEW integration available. Please contact Comsoft for further information.
Thanks and kind regards,
Jochen Klier
02-04-2010 03:11 AM - last edited on 03-11-2024 08:48 AM by Content Cleaner
National Instruments actually sells Profibus boards for PCI or PXI-systems. For more information:
https://www.ni.com/en-us/support/model.pci-profibus.html
These PROFIBUS PCI and PXI one-port interfaces connect PC-based controllers to PROFIBUS industrial networks as powerful masters or slaves. PROFIBUS interfaces include an NI LabVIEW driver for human machine interface (HMI) and SCADA applications. You can also perform PROFIBUS device automated test using these interfaces.
With LabVIEW Real-Time support, you can add PXI or PC systems as slave or master nodes to a PROFIBUS industrial network. Featuring more than 20 million installed nodes, PROFIBUS is one of the leading industrial networks for reliably connecting programmable logic controllers (PLCs), I/O, sensors, and drives over long distances in industrial environments.
Casper
02-04-2010 03:49 AM - edited 02-04-2010 03:49 AM
I'm sorry I misread the initial question. National Instruments does provide a profibus option but not (yet) a profinet option. I'm sorry for the confusion.
Regards, Casper
02-22-2019 02:37 PM
Can the PXIe-8840's second port eth1 as EtherCAT Master ID: 0 communicate with ProfiBUS and ProfiNET via EtherCAT protocol if configured in Veristand's System Explorer?
