Industrial Communications
Reply
PXI PROFIBUS Interface Module multiple slaves
Highlighted
Can the PXI PROFIBUS Interface Module emulate multiple slaves at once or can it only emulate one slave?
(833 Views)
Accepted by topic author james123321
07-24-2018 08:11 AM
Re: PXI PROFIBUS Interface Module multiple slaves
Hey James, I just happened to be browsing and saw this.
One slave at a time.
If I remember correctly, you can download a new configuration set up to the PXI card to change the parameters of the slave it's emulating, but this takes a few seconds (~10).
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(828 Views)
a_cluker,
Do you happen to have documentation about this?  I'd like to read more into it.
Thanks.
(789 Views)
Hi Jenkins,
This was from an old issue I worked on. After some digging I found the code - it's not the prettiest - but it shows the basics. Essentially you're just modifying the address field of the slave blob.
In the project I used a cRIO PB as the master, so you might see some broken items if you don't have that driver installed. You can ignore that (as it was just the master I used) and focus on the PXI-PCI Slave Main.vi. If I remember correctly, the code was last saved in LabVIEW 2013 SP1.
Andrew T.
(766 Views)
