Industrial Communications
PXI-8532 Output Supply
Does anyone happen to if the output voltage of the PXI-8532 can be software selected between 10V and 30VDC? Our particular test application requires testing a DNET device at max and min supply voltage.
Thanks!
(6,112 Views)
Yes, the board has a Vbat Input to take external power supply between 10 and 30 volts.
DirkW
(6,106 Views)
Would you happen to know the difference between the CAN Reference GND and the Optional CAN Reference GND shown in the Datasheet? From my research I believe the only connections I need to make are CAN H, CAN L, and CAN REF GND? My DNET device will have its own seperate supply, im assuming?
(6,100 Views)
Let me correct myself, what I mean is that I do not need to supply power to the DNET card.
(6,096 Views)
Yes, the board doesn't need external power it is supplied internally.
DirkW
(6,088 Views)
