05-21-2013 01:44 PM - last edited on 03-07-2024 03:05 PM by migration-bot
Hello
I recently upgraded from a PXI 8461/D (https://www.ni.com/en-us/support/model.pxi-8461-d.html) to a PXI 8532 (https://www.ni.com/en-us/shop/model/pxi-8532.html) which required a driver update from 1.6.7 version used on the 8461/D to the newer driver 2.2.0 used on the 8532. After following the migration instructions for switching from 1.6.7 version to 2.2 version when I go to run the program OpenDeviceNetexplicitmessaging.vi along with several other VI’s will give me an error. Do you know how to correct these errors?
Hardware & Software being used:
Dane
05-23-2013 01:35 PM
Additional information concerning DeviceNet problems we are experiencing:
05-23-2013 01:38 PM - edited 05-23-2013 01:39 PM
Here are the addition vi's that were in the previous posting (the numbers are the end of the vi name indict what version driver it was used with)
05-24-2013 08:25 AM
You are using these MFC... Vis which I do not understand where they are coming from. It looks like these VIs are different enough to break the new driver.
To understand the issue I would need the MFC source Installer or VIs to debug. Right now if I open the Vis attached I get all kinds of errors because I am missing ressource files.
DirkW
05-24-2013 11:08 AM
If you have Labview 2012 SP1 along with the DeviceNet version1.6.7 drivers and 2.2 drivers the only errors you should receive are from our error handler which you can disable in the VI. If there are any other errors and/or files you need lets us know.
I have attached MixedComm2.vi which is an example from NI which was the basis for our VIs
