Industrial Communications
Need a VI to link to historical modbus data and produce a Graph on the VI and have the ability to write to .xls file for a specified range of time
I am trying to create a VI that links to a Modbus I/O variable that I access through NI DSM: The VI need to be able to select (hopefully by a drop-down) a test unit we have that is currently reading temperature. It then need to be able to access (trace) the historical data it has been logging and produce it to a waveform/graph. I also need the ability to specify what date/time range I want to see on the waveform/graph. I am trying to set this up for the lab technicians so they can select a test unit on the VI and view on a graph, the temperature data from the past day/week/ etc range that they need to see. If there is an issues, they need a way to save that range of data to an .xls so they can plot/print the data to present to superiors. Attached is the NI DSM and the VI that I have started to attempt to build. I'm very new to this and do not have access at work to the tutorials or YouTube as refereance sources. Am I headed in the right direction?
(4,919 Views)
attached is the new VI i am trying. Maybe this is the correct direction?
(4,914 Views)
Hi ACFNST,
Mike gave you several good pointers in your other post, many of which I would I would give you as well.
Best Regards,
Matthew B.
Offering Manager
NI
(4,903 Views)
