07-14-2019 11:05 AM - edited 07-14-2019 11:09 AM
I would like to use one of NI products with Ethernet/IP (CIP) support like gateway for an other acquisition system. I have one acquisition system (not NI) with AI (analog inputs), DI (digital inputs) and CAN (2.0 A and 2.0 B). I need each variables at least of 10 ms.
Solution 1: To use one NI controller with Ethernet/IP (cRIO/PXI or other) + CAN board?
Solution 2: To use one NI controller with Ethernet/IP (cRIO/PXI or other) + AO (analog outputs)?
Solution 3: To use one NI controller with Ethernet/IP (cRIO/PXI or other) + DO (analog outputs)?
NI proposes différent products with Ethernet/IP on the site with PXI, cRIO interfaces ( http://www.ni.com/pdf/manuals/374775g.html#overview) but without the concrete list of product references, please see the extract below:
Hardware Support
NI-Industrial Communications for EtherNet/IP supports the following NI hardware products:
Note NI-Industrial Communications for EtherNet/IP 19.0 does not support PXI or PXIe devices with NI Linux Real-Time.
Could you please help me to find the list with of NI products (cRIO, PXI and others) which support Ethernet/IP ? Which NI PXI controller support Ethernet/IP?
Thank you,
Networker
