07-15-2019 02:00 PM
I have a need to connect to a Profibus DP network. Since Profibus DP and Foundation Fieldbus are ELECTRICALLY identical, can I use this module to connect to a Profibus DP network even though it is targeted at a Foundation Fieldbus network? I have a NI USB-8486 and a program that needs to interface to the Profibus DP network and want to know if I can use this adapter to access the Profibus DP network.
07-16-2019 07:45 AM
No, unfortunately not. Even though both protocols use the same physical layer, the 8486 is locked to the foundation fieldbus driver and will not work with any other fieldbus.
-DirkW-
07-16-2019 09:07 AM
I think it is Profibus PA ( not DP ) that is the same physical layer as Foundation Fieldbus
