08-03-2014 04:43 PM
Hi Guys,
I am new to labview and I was playing around with labview file and accidently changed the CRBO for control relay output block to a pushbutton,now I cannot/ dont know how to revert it back.
Now Labview is showing many errors,like "subVI" not executable,polymorphic sub VI is broken.I have no cluse what these means.
I am using labview 2013.
I am using labview 2013 as a dnp3 master to some sel relays.
I made this dnp3 file by modifing the example dnp files form NI.
Pls help me get this setting back.I have also attached an image regarding the same and also the labview file.
Do I have to reinstall Laview completly to get the old settings back.I am quite sure the files I made are working fine because I had checked it before trying to modify the CRBO(trying to make it look simple)
Please Help mE
Leon Koshy
08-04-2014 03:31 AM - edited 08-04-2014 03:32 AM
Hi Leon,
You may have modified the typedef of the terminal CROB.
Reinstalling DNP3 alone will cure the problem, I believe. You don't have to reinstall LabVIEW.
The VI you attached opens with no error. It's executable.
