Industrial Communications
Modbus RTU over TCP/IP
Dear All
I am looking for  Modbus RTU over TCP/IP example VI. Does anyone  have experience with this protocol?
Please kindly give me some advice!
Thanks and Regards
Luong.Tran
(8,239 Views)
Accepted by Luong.Tran
Start here for more information and the LV ModBus lib.
Kees
(8,235 Views)
Hi Luong,
The Modbus Library posted by K C is the older version not supported by NI.
I would recommend using the updated library on NI Labs created by our Systems Engineering group.
Additionally, if you have the DSC module, you can use built in Modbus functionality using I/O servers.
Matt S.
Industrial Communications Product Support Engineer
(8,224 Views)
Important addition:
That library works for 2012-current and is still not supported except by me. Meaning if people ask a question and I'm on vacation the question generally doesn't get answered.
If you have LabVIEW 2014 and either RT or DSC, you also get the R&D supported version of that library. This means you can call into AE support and get help with it.
(8,203 Views)
Hello! I am worried about this topic. Not a simple thing, but Modbus TCP/IP is one kind of Modbus protocols designed for controlling and supervising equipment over TCP or IP. It is possible to use Modbus over Internet or Intranet if a device supports TCP/IP sockets and you know how to execute a TCP driver. It explains how it works and what can be associated with https://www.eltima.com/modbus-over-ethernet/
(4,100 Views)
