01-20-2014 02:58 AM
I want to migrate a NI-CAN application to NI-XNET. My application run on a NI-PCI-CAN series 2 and i need it work on a NI PXI-8512 .
I develop with delphi.
I followed the "Migrating NI-CAN Applications to NI-XNET" tutorial : http://www.ni.com/white-paper/9717/en/
I can see the card in MAX like explain in the tutorial.
I realised a small application who show the receive data. That application work well with my first card but didn't work with the new.
From the NI-CAN library i use : ncConfig, ncWaitForState, ncOpenObject et ncRead.
I want my NI-CAN application work on my new card without touch the source code. Is it possible?
Solved! Go to Solution.
01-22-2014 09:40 AM
That tutorial is only for LabVIEW. I think you will have to modify your source to use the new card.
01-27-2014 04:56 AM
So i will have to modify my source code.
Thank's for your answer.
