Industrial Communications
IGES or STEP file for PXI PROFIBUS & PXI 8532 (DeviceNet)
Friends,
Where can I find either IGES or STEP file for PXI PROFIBUS and DeviceNet?
I have collected other component details but couldn't find these two of my system.
Thanks in advance.
(4,038 Views)
I'm digging deeper into this question internally. So far, I have not found one for either.
However, the PXI 8512 (1-port CAN) is physically identical to the PXI 8532. The dimensional drawings for the 1-port PXI 8512 are located here.
I'll post again if there's any additional information Smiley Happy
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(4,006 Views)
Just heard back about the PXI 8532. Use the PXI-8512 drawing, as the two cards are physically identical from that perspective. Is that sufficient for your needs?
I'm still looking into the DF PROFI II.
Andrew T.
(3,990 Views)
Accepted by topic author mini09
Below is the drawing from KUNBUS for the PXI DF PROFI II.
Andrew T.
(3,933 Views)
Thanks Andrew... Appreciate your support. As you suggested we used the same 8512 for DeviceNet....
(3,756 Views)
