07-12-2017 07:30 AM
Friends,
Where can I find either IGES or STEP file for PXI PROFIBUS and DeviceNet?
I have collected other component details but couldn't find these two of my system.
Thanks in advance.
07-12-2017 03:44 PM
I'm digging deeper into this question internally. So far, I have not found one for either.
However, the PXI 8512 (1-port CAN) is physically identical to the PXI 8532. The dimensional drawings for the 1-port PXI 8512 are located here.
I'll post again if there's any additional information
07-13-2017 04:22 PM
Just heard back about the PXI 8532. Use the PXI-8512 drawing, as the two cards are physically identical from that perspective. Is that sufficient for your needs?
I'm still looking into the DF PROFI II.
07-24-2017 09:12 AM
Below is the drawing from KUNBUS for the PXI DF PROFI II.
08-14-2017 03:47 AM
Thanks Andrew... Appreciate your support. As you suggested we used the same 8512 for DeviceNet....
