Industrial Communications
IEC 61850 data object creation
Hi, Is it possible to create new Data Object (i.e. not-standardized ones) inside the LNs (logical node)
Thank you
(2,490 Views)
Hi
Yes, you can do it.
You can use a tool SCL editor or edit directly into the XML file, but have in mind the association between atributes and Data Template.
I recommend you to use the software Helink or Trial TriangleMicroWorks.
Best regards
(2,445 Views)
thank you!
(2,443 Views)
