Industrial Communications
I want to EtherCAT Master using Beckhoff C6015-0010 (C9900-C583)
I have a Beckhoff C6015-0010 (with C9900-C583).
This pc is ultra compact industrial PC with ethernet 2 ports.
I installed NI Real-Time Desktop PC in this.
It worked on RTos very well with LabVIEW. (targer searching, debug, deploy)
But RTos can not work when I set network option to EtherCAT (2nd ethernet port) in MAX.
I can not find RT target in MAX. and project in LabVIEW.
How can I work EtherCAT Master in this pc?
Please help me.
*additional infomation
LabVIEW 2015 sp1 (RT module)
Device driver Feb.2016
Beckhoff Ethernet chip : Intel I210 Gigabit
(4,505 Views)
Accepted by topic author -max-
NI EtherCAT master only supports the following hardware. Can you please have a check?
EtherCAT Master Earliest Supported Version
cRIO-9074 1.0
PXI-8106 1.0
PXIe-8130 1.0
PXI-8104 1.0
PXI-8183 1.0
PXI-8145 1.0
cRIO-9022 1.01
PXI-8108 1.01
cRIO-9024 1.1
NI 3100 1.1
NI 3110 1.1
cRIO-9023 1.2
cRIO-9025 1.2
NI 9792 1.2
EVS 1463RT 1.2
EVS 1464RT 1.2
All real-time embedded PXI controllers with the PXI-8231 or PXI-8232 Ethernet interface 2.0
PXIe-8133 2.0
PCI-8232 2.0
PCIe-8231 2.0
PCIe-8233 2.0
PCIe-8235 2.0
cRIO-9081 2.2
cRIO-9082 2.2
RMC-8354RT 2.5
RMC-8355RT 2.5
PXI-8109 2.5
PXI-8115 2.5
PXIe-8115 2.5
PXIe-8135 2.5
cRIO-9068 2.6
cRIO-9030 14.0
cRIO-9031 14.0
cRIO-9033 14.0
cRIO-9067 14.0
sbRIO-9651 14.0
cDAQ-9132RT 14.0
cDAQ-9134RT 14.0
cDAQ-9139RT 14.0
PXI-8840 14.0
PXIe-8840 14.0
CVS-1457RT 14.0
PXI-8119 14.0
PXIe-8119 14.0
PXIe-8880 14.0
cRIO-9035 14.5
cRIO-9036 14.5
cRIO-9038 14.5
cRIO-9039 14.5
cRIO-9064 14.5
cRIO-9065 14.5
cDAQ-9133RT 14.5
cDAQ-9135RT 14.5
sbRIO-9607 15.0
sbRIO-9627 15.0
cDAQ-9136RT 15.0
cDAQ-9137RT 15.0
CVS-1458RT 15.0
cRIO-9032 16.0
cRIO-9037 16.0
cRIO-9035 (Sync) 16.0
cRIO-9039 (Sync) 16.0
IC-3171 16.0
IC-3172 16.0
IC-3173 16.0
cRIO-904x 17.6
(4,490 Views)
Oh..... Thank you very much.......
I found additional infomation in "INSTALLATION GUIDE NI-Industrial Communications for EtherCAT®"
http://www.ni.com/pdf/manuals/372624f.pdf
According to this document,
"By default, some real-time controllers, such as Real-Time Desktop controllers, do not have the special Ethernet adapter to access the EtherCAT network. Refer to the list of supported hardware in the NI-Industrial Communications for EtherCAT Readme for more information about the additional adapters that you can add."
(4,479 Views)
