12-16-2011 08:59 AM
I have purchased this board from NI. I have been in touch with Comsoft who it appears is the developer of this board. I have used the configurator II to try and build the network. The GSD file for my slave board is entered. I also can see the GSD file for the master. There appears to be no obvious way to test the bus from the configuration tool. I have tried the Express VI provided by Comsoft. Nothing happens. I have a purchased profibus cable with terminations installed. I know the cable works as another division has another Profibus master that does work using this cable How do I configure correctly for sure? How do I test?
Rick
12-19-2011 11:34 AM
Hi Rick,
Everything you need to know about setting up your Profibus device can be found in this Getting Start Tutorial. The instructions for setting up the device can be found under the "Device and System Startup" and programming instructions can be found under the "Programming Model" section. Hope this helps,
12-19-2011 12:41 PM
NI field Rep was here for 2 1/2 hours. We attempted to follow these directions and could not get it to work. I know the cable is good. I know the slave device I am trying to communicate with is good. both have been verified.
Any other suggestions?
Rick
12-20-2011 09:03 AM
Hi Rick,
First, ensure that you have the correct drivers installed on your system:
However, it sounds to me like you may have an issue with your bus configuration or with the GSD file. First, did you obtain the GSD file from the manufacturer or from profibus.com?
Also, common issues with the configuration include specifying an improper baud rate (supported baud rates can be found here), or an incorrect PROFIBUS address. Were you able to successfully save the bus configuration and generate the configuration database? Were you able to load the configuration database into the master device successfully as well?
If you are unable to resolve this issue, can you provide me with some more information about your system setup and error? What PXI chassis are you using, version of LabVIEW, operating system? What devices are you testing on the bus?
12-20-2011 10:22 AM
I believe the first 5 steps were followed correctly as the self test for the board in Max works. When I selected baud rates the configuration tool detected and reported an issue if the baud rate was not supported by the slave which is our board. Our board is reg with the profibus site. works with a different profibus tool just fine.
Visa version is 4.2
Labeled 8.0
Windows XP
PXI1010 chassis. This is the second of two chassis. MXI 4 link connects the two.
12-20-2011 10:27 AM
Sorry Labview version is 8.0.
The error seems to be that the configuration tool is looking for the device at the address I have installed it at. In this case address 7. I have tried other addresses. Also tried the Labview Express Master VI. This also fails. Should read what is on the bus.
Rick
12-21-2011 08:43 AM
The issue has been solved. In the configuration tool, after the slave device is connected to the network, All the attributes listed underneath it must also be dragged over and placed in the listing that appears. Never saw this step in the documentation. Once that was done the configuration tool could initialize and find the slave.
Rick
10-10-2013 04:57 AM
