Hi, we are using cRIO 9074 to control a robotic arm by KUKA controller. We wanted to use Ethercat for ease of use and minimum hardware requirements. The KUKA controller comes as a master by default. Before jumping to other protocols, I want to explore any possibilities of making my cRIO behave as a slave in Ethercat. If I add 9144 chassis in between, it would have two masters and only one could have write access. I want both the controllers to be able to send messages to the other end of the chain?
How do I achieve this?
