03-19-2019 08:53 AM
Thanks for the LV2014. I will look into it and post an update once I make progress.
11-06-2019 06:15 AM
Hello Urs,
I do not think you are anymore interested in a reply (now !) taking into account you posted nearly 2 years ago. Anyway, you can download Labview,Tools, VI Package Manager … : NI Modbus library ( Version 1.2.1.42)
Thanks to that Modbus library you are able to communicate with the Comtrol master via Modbus. Use VIs like Write Multiple Holding Registers.vi & Read Holding Registers.vi to access the IO-Link data
Greetings
Laurent
05-22-2020 02:59 AM
Hi
We prefer to use Ethernet/IP to connect to IO-Link devices.
The company Kirschenhofer has programmed a Ethernet/IP driver that allows your application to function as a IP scanner.
You can download the driver for free HERE . I know they have a add-on for the IO-link master from Turck, but you might have to contact them directly, as it is not yet implemented into the standard library. I have tested it and it works fine.
Hope this helps.
10-07-2020 02:08 AM
Hi a.wais
Is it possible to get a copy of this driver You have tested?
I need some easy access from LabVIEW to an IO-Link device. So, this sound like an option if I buy some Kirscenhofer HW as gateway, right?!
BR Jorgen – DK
09-22-2021 03:14 AM
I was also looking for IO-Link and I found this GPower driver. It's not free though ☹️
12-14-2021 09:29 AM
Thanks for reffering to our page Michał. 👍
Yes, we have indeed created a toolkit for connecting IO-Link devices to LabVIEW or TestStand.
The toolkit makes integration to IO-Link devices very easy - Plug and play! The software understands the IODD files that comes with the sensors/devices, so you can pick the parameters to read/write and see their properties like Max or Min values and other properties.
The toolkit works with a lot of different masters. See the list of supported masters on our website.
We have spend a lot of time developing the product, and therefor we can't offer this for free. But you will save a lot of time with integration, and get an easy configurable solution. You are very welcome to try a free 30 day trial version. The demo can be requested through our website.
Check it out: https://gpower.io/en/products/io-link-labview-teststand/
Don't hesitate to contact us if you need to integrate IO-Link with LabVIEW or TestStand.
01-13-2022 10:10 AM - edited 01-13-2022 10:11 AM
I like how Rolf explained the problem of sharing code for free. I have mixed feelings but I understand 😉
01-26-2024 08:57 AM
2024 has entered the chat. Is there a plan (or is it even feasible) for GPower to add IO-Link support for FlexLogger as well? Perhaps via the FlexLogger Plug-In Development Kit?
