11-27-2018 11:20 PM
yes i have installed it
how can i communicate with the sensor and get the data through that
could you please help me out on this
11-27-2018 11:27 PM
i have installed it in my machine
could you please help me out to communicate with the promass
11-27-2018 11:29 PM
i have downloaded and installed etherner ip toolkit
01-10-2019 02:26 AM
Hi @Suyam, sorry I forgot to reply before.
Have you made any progress with communicating with your flow meter?
The key is to use EthernetIP CIP Get Attribute Single.vi to read your flow meter's input. The order of the input parameters is listed under "Permanently assigned input group" table at https://portal.endress.com/wa001/dla/5000594/1278/000/01/BA01182DEN_0214.pdf (page 48)
01-21-2019 12:30 AM
Could you please post the sample measuring Labview Vi
i can able to read the data from the promass 100 . i am facing issues with parse or converts the data into normal format (data being coming from the promass is HEX format)
01-21-2019 01:12 AM
I'm glad to hear you can read data.
I only read the Assem100 data, which is an array of 11 floating-point numbers (SGL).
EthernetIP CIP Get Attribute Single.vi returns the data as an array of bytes (hex). Use Type Cast to convert the 44 bytes into 11 SGL numbers:
To understand the Type Cast function, see https://forums.ni.com/t5/LabVIEW/I-need-To-Understand-the-quot-Type-Cast-Function-quot/m-p/1462738/h...
01-21-2019 01:34 AM
Thanks for your great help
i have attached front panel and block diagram of my code
there are 11 parameters i can converts .
but i have a doubt that not matching with the data which is reading in the device
01-21-2019 01:36 AM
04-16-2019 01:26 AM
HI
PLease help anyone how do i match with the display data of Promass 100
10-30-2020 09:16 AM
Hi all,
long time ago since your last post... anyway:
I need for my machine a E&H Promass F 100.
There is still no simple way to get the data to my labview application.
Now the question for me is: Which interface should i use (buy): Ethernet/IP-Interface or Analog (Hart) Signals?
Have you been successful to read the matching data from the Promass f 100 into labview via Ether/IP?
If yes, can you show me your vi?
Thanks and BR
