Industrial Communications
Reply
Failed to parse the SCL file
Highlighted
Hello
I am currenly using a cRIO-9075 in order to implement it as a IED. I want to publisher GOOSE and MMS using the Example VIs, but I get an error -36290 that is attached.
All the configuration is also attached.
Could you please help me?
(387 Views)
回复: Failed to parse the SCL file
Hey
NI-Industrial Communications for IEC 61850 15.0 Readme state that GOOSE only support cRIO-906x and cRIO-903x. I suggest that you use a new target and have a try.
Thanks!
(182 Views)
