Industrial Communications
Ethernet IP toolkit Omron CJ2M PLC
You are welcome, Rick. And thank you for sharing your knowledge.
I think your question in this step is more related to the EIP format differences between two Omron PLC types.
I'll keep monitoring this thread and give my help if I know better.
Message 11 of 23
(8,192 Views)
Dear Sir,
I am facing same problem with Communication between NJ series PLC.
Any solution you found to read and write boolean data type? Please help.
Thank you
Regards  Ishan
Message 12 of 23
(6,022 Views)
Hi Ishan,
This thread is a couple of years old, so I suggest posting in a new thread to make sure you get responses to your question.
Cheers,
Ryan
Message 13 of 23
(6,008 Views)
Hi Ishan,
I have not worked with the NJ series yet. This is what I have for the CJ series. Sorry, the attachments are Labview 2014 format. So I took a couple of screenshots.
The Host IP for my setup is 192.168.250.1,1,0 and the Tag Name is the Symbol name created in CX Programmer.
Hope this helps.
Regards
Rick
Message 14 of 23
(6,005 Views)
Dear Sir,
Currently I am also working on CJ Series & I use ETN-21 Card.
I got the network path error.
How to Configure ETN-21 Card?
Message 15 of 23
(5,653 Views)
Dear Sir,
The Snaps you Post is also work for NJ Series & it Helps me a lot.
Thank you
Message 16 of 23
(5,650 Views)
I found this document put out by Omron for connecting an NJ to an Allen Bradley PLC. Not sure if it helps with your issue or not.
https://industrial.omron.us/en/media/NX-S_Standalone_QuickStartGuide_en_201502_QSG-NX-S-Standalone_t...
Jordan
Message 17 of 23
(4,644 Views)
GREAT JOB rpage !!!!
You're my savior!!
I was using the unofficial ethernet/ip with AB PLC and I was looking for a solution to make it work with OMRON PLC and here I found the answer.
I was able to read string and boolean using RAW datatype and real using the REAL vi. But no way to write.
Following your instruction and your example, now i can read and write every kind of data i need.
Maybe if I have some spare i will post some VI ready to be added to the toolkit.
Geppo!
Message 18 of 23
(2,301 Views)
Hi Geppo,
I am glad this info is still helpful after all these years.
-Rick
Message 19 of 23
(2,288 Views)
I supposed to but not... I Can't write REAL datatype.
I'm not sure on How to build the byte array to write to make the array acceptable for the write.
I Have to use CA as datatype but then? If I had to write a number like 202,00?
Message 20 of 23
(2,250 Views)
