Industrial Communications
Reply
Ethernet/IP implicit messaging is possible in labview PC
Re: Ethernet/IP implicit messaging is possible in labview PC
Hi fra_sab,
If it can get the response with the correct size. I think it has succeeded to communicate with the device. It's possible that the area is all zero. You should contact the device's company for more detailed information.
Did you do a test with other vi? Is there any problem?
Thanks!
Message 11 of 11
(266 Views)
